- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xeperia 1V Bluetooth remote
Hi, I have a Sony Experia 1V.
Could anyone tell me if there is a bluetooth remote commander / shutter
relesae that is compatible with both the Photo Pro & the Cinema Pro apps. I purchased the Sony RMT-P1BT,
which works fine with Photo Pro, by going in the settings menu, but can't find anything in the Cinema Pro settings.
Someone posted somewhere that the Sony RMT-P1BT will only work with Video pro app, not with the Cinema Pro app.
Could anyone help or advice with this please?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Markie100
Yes, you can connect to a Bluetooth remote or grip, check this one: https://helpguide.sony.net/mobile/xperia-1m5/v1/en/contents/pair_bluetooth_remote_commander_grip.htm...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, thanks for your help. I did see what you have posted, however it will only work with video pro & not with cinema pro, which seems strange as it works with older phones but not the latest flagship phone. I don't know if they could make it compatible with the 1V with an update.
Thanks Mark.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, I checked the instructions on the Cinema pro from the help guide https://helpguide.sony.net/mobile/xperia-1m5/v1/en/contents/launch_cinema_pro.html?search=cinema
And it seems that it doesn't have the option for remote shooting by BT like the Video Pro app https://helpguide.sony.net/mobile/xperia-1m5/v1/en/contents/video_pro_settings.html?search=remote
