Connecting phone to PC by USB cable
Seasick_Steve81
I have just tried to connect my Xperia 10 to my PC via a USB cable so I can transfer some files to a USB stick. When my phone is switched on it does not work but when I switch it off the red light on my phone comes on to tell me it is on charge. It worked fine a couple of days ago but now nothing. My PC is not the issue here as all the USB ports work fine as I have tried to put in a USB stick in the same port I plugged in the USB cable. Does or has anybody had the same problem & if so do you know how to solve it. Thanks
1 REPLY 1
profile.country.PH.title
MarlonUk1
Are you using the USB cable supplied with the device?
After connecting your device via the cable there will be a prompt on the device to connect.
Not all USB cables are specified to transfer data.
