Hello
SSometimes when I start my Sony xperia 10, say after turning it off and charging it up, I have a little triangle with a hammer and screwdriver show up on the screen (🛠) before my phone has done anything else.
What does this symbol mean? Should I be worried?
Thanks guys
Sholah
Honestly I don't know, but if it was my car I would say it's time for maintenance.
Let's wait for the smart guys over here to give you an answer.
I have the same problem ever since the android 10 update, I did a factory reset, reinstalled the firmware via xperia companion. and the triangle dissapeared upon boot. but after a month it started showing up again. other than that it does not affect the performance of my phone. but it did not do that with android 9.
