USB charging
Proberts13
USB charging
Hi.
Xperia 10 ii will not charge using usb charger in my car, and can't find any settings to allow.
I'm in the uk, I have tried the same cable from the house but nothing, in the car.
14 REPLIES 14
Proberts13
Oh ok, I don't see the developer main options, to get to see the toggle either, would Xperia 10 be different?
IamNic
Hello @Proberts13,
you have to activate them or in this case be already connected so the menu becomes clickable.
- Nic
profile.country.NL.title
Strampke
To get things clear.
- Your device does charge at home with a charger.
- Using the same cable your device does not charge in the car when connected to the USB port
- Other devices charge in the car using the same cable.
- In all cases ignition in the car is on. USB has power.
- You tried another cable to connect and it gave the same results.
This picture you showed.
Everything is faded.
This menu is active when you connect your device to your computer.
This menu should be active when your device is connected in your car.
Best guess so far is to have a look at the USB plug in your car or the USB connector of your device.
Proberts13
Hi Nic
Result but feeling stupid, as it was the cable not charging my Sony, but the cable was charging my work phone Samsung.
Strangely I have swapped by Samsung cable to car and it begins to charge my sony, so good news mystery solved.
Thanks for your help, much appreciated 👍
Proberts13
Hi Strampke
It was the cable all the long.
Thanks for you help
