- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
5 II bluetooth headset and microphone issues, only outgoing calls
Hi there,
got a 5 II a week ago as an amazon warehouse offer, then installed about ten major updates, running version 58.1.A.5.507 now.
On outgoing calls via bluetooth headsets using the preinstalled google phone app the called party can barely hear me, only about 10% of those calls sound normal. Incoming calls, WhatsApp calls calls using the built-in mic work fine, the headsets work properly with other phones.
What I tried: different sim cards/providers, wifi calling, different headsets, network reset, factory reset, all kinda different developers settings regarding bt. Nothing helped.
Any suggestions? Anyone facing the same problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @ MUC80335,
Does this issue happen when you make or receive calls without any BT headsets ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, incoming and outgoing calls without bluetooth headsets are alright.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This could be a compatibility issue between the BT headset and the phone.
Did you try to test another headset with the phone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, four headsets from three different manufacturers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try to reset the connection and troubleshoot the Bluetooth app like clearing cache and data and force stop.
If that didn't work, try the software repair by the Xperia Companion as the last option and check again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you so much, the software repair using the Xperia Companion made it work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Oh I'm glad t hear that and you're most welcome
