A7 IV - setting aperture & shutter speed
shabbagaz
This may be a stupid question so apologies in advance if I come across as an idiot!
I have an issue in 'manual mode' where I can't set the aperture and shutter speed separately. Every time I try to set one, it adjusts the other at the same time.
I'm not sure why it's started doing this - possibly something I have inadvertedly pressed.
I've tried resetting my settings and have also Googled solutions - sadly they have proved fruitless.
Can anyone provide a solution?
Many thanks!
2 ACCEPTED SOLUTIONS
danardeng
Contributor
You are not in "M"!
You are in "P" recalled from memory setting "2".
Be sure that your ring is well placed as here
7 REPLIES 7
danardeng
Contributor
I have to answer with a stupid thing’s: are you sure that you are in “M” mode and not in “P”?
shabbagaz
Yes I am in 'M' mode.  First thing I double checked.
danardeng
Contributor
Actualy I don't remember any setting that can cause that...
Can you share a pic of the back of you screen with all parameters visible, just to see if I see anithing usefull?
shabbagaz
danardeng
Contributor
You are not in "M"!
danardeng
Contributor
shabbagaz
Head in hands moment, I know exactly what I did, I looked at the wrong marker!  Thought I was in 'M' when I wasn't!
Saving the settings I wasn't aware of - many thanks for that as that will come in useful.
