SEL15F14G is missing on my sony
profile.country.FI.title
kollikoukku
I can't register my new lens, because it is missing?
Tags (1)
12 REPLIES 12
Anonymous
Not applicable
I think you will need to contact the Finnish support as they might need to add it to the website if it's missing since you can find it on the UK website.
kollikoukku
I did, but they can't do nothing.
Piscie
Hello @kollikoukku, make sure to enter it as SEL15F14G or E 15mm F1.4 G and select it from the drop down menu. Also test different browsers from your PC or Laptop. If that didn't help. I'd recommend contacting Sony reps directly to sort this out for you.
