Dear Forum
OMG finally got my hands on this TV after being such a good boy for many months and thanks to JL dropping it to £990 on Black Friday that sub 1K price tag was all that was needed to get a "Go on then" from the Generalismo.
Everything is absolutely sweet, Blu ray performance 4K Dunkirk OMG, Rugby in UHD wow and Sir David Attenborough's latest series stunning.
However my Sky Q box is refusing to recognise the TV as a 10 BIT model and keeps defaulting to 8 BIT.
Have a missed a trick in set up? Do I need to alter the deignation of the output HDMI somewhere? I suppose the question is will I actually notice a difference?
Current set up is KD55XF9005 via optical into SKY Sound Box, HDMI from 2TB Q box into Sound Box out into HDMI1 and Sony UBPX700B into HDMI2.
Thanks for any advice hopefully something simple I have missed!
Hi, 10 bit only works on hdmi 2 and 3 you need to put sound box to hdmi 3 ARC also you need to set the hdmi input to enhanced setting in the tv settings. I hope this helps you.
Top man worked perfectly thank you.
hi, ok setup port HDMI in 4k but is necessary to change the parameters in setup android but i don't find if you want to help me thanks
