KDL-32WE613 No picture, only sound
Stanby
The picture went off. Tried switching off etc. Can't do a factory reset as no picture! NB Has been on 24 hours a day for a couple of years.
5 REPLIES 5
Stanby
Sorry guys, it's a KDL-32WD75x, if that makes any difference!
Stanby
Update. I switched the tv on again after a couple of hours, and there was the picture. Hurray I thought, but 5 minutes later it went off again, sound is ok. Weird.
rooobb
Not a common consumer user scenario I should say it seems simply that some hardware component failed, not something that a community could solve
Stanby
duly noted!
SkyNet404
Specialist
Hey there,
If a forced reset won't help: https://bit.ly/39z6LmF
Then you might need to check this with an engineer as I think it needs to be repaired at this point: https://bit.ly/3uaZzZa
Hope this helps.
