KDL-40WD650 failed to startup, LED red blink 4 time
samuel.tang
it suddenly happened, and won't recover again. every time turn it on, it will go into the state, RED LED blinks 4 times again and again(interval maybe 3 secs). could anybody know what happens to it? thank you.
4 REPLIES 4
Pascale_F
Moderator
Hi Samuel,
Welcome to the community.
I'll see if I can track down some help. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
samuel.tang
Thanks, looking forward to your solution.
Sent from my iPhone
LightFoot
Specialist
Hi @samuel.tang
The red led blinking is not a good sign. It normally indicates a hardware failure requiring a repair which may cost more than a new TV.
If you haven’t already tried it, disconnect from the mains electricity for at least 5 minutes and disconnect everything connected to it.
If all else fails you need to contact  Sony UK Support  to see what your options are.
The_Black_Rose
Specialist
Hi Samuel.tang,
I looked this up on the Sony website and it says that the TV requires repair. You can use this link to locate the nearest service centre to you: https://locator.sony/en_GB/servicecenters
Cheers,
The_Black_Rose
