Partagez votre expérience!
KDL-43W807C does not update neither over WiFi nor manually via USB stick to v2287.
Over WiFi downloads up to 97% and then get error code 2123 and no update. When downloaded the update onto my PC, unziped to USB, then plugged into TV set, but file copies to 97% and then TV reboots but not updated.
Please help.
Résolu ! Accéder à la solution.
Hi,
Please call our call centre for this issue as we will definitely not be able to solve this online ![]()
Nico
Hello,
Thank you for your answer.
I phoned the support. They said me just to report the issue by email and wait until they will figure it out.
Geting same issue, doesnt even look like the file on USB is correct.
