KD-55XG9505 Android 8
Is there any facility to control the auto light sensor. My past TVs have all had settings to do this. With Toshiba you could even construct your own non-linear curve!
It drops the brightness too low for my room.
(The Dolby Vision “Dark Room” setting also goes down too far for me)
Seems a bit weird that I can’t customise them?
I wish the same , my old LG was the same it was off or on , the Samsung I had was adjustable , Im not sure if any of the Sony's are .
