Sony Bravia KD-55x9005cbu - Ethernet Port
johnnieboy
I wish to connect the above to my Superhub 3.0, however I can't find an ethernet port in the back. Can anyone help. Also, I can't find a drawing showing the layout of the ports anywhere, does one exist?
Regards, John
1 ACCEPTED SOLUTION
3 REPLIES 3
Manolo
johnnieboy
Brilliant Marino,
Many thanks
Regards, John
A picture is worth a thousand words... :slight_smile:
Manolo
