Sony KD-55AF9 Home screen shortcuts disappearing
profile.country.AE.title
khaeid2
I have normal installed apps on my Android TV, (apps that can normally be added to the home screen without the use of Side Launcher), like FX file explorer or others, I add the shortcut to the home screen, and over night the shortcut disappears from home screen, and I have to add it again.
This issue did not occur before, it only started after I did total memory initialize couple of weeks ago.
I tried turning TV off and on, and rebooting the TV after adding them, the shortcuts stayed there, but still they disappeared overnight.
Very weird, and I don't feel i should need to replace the stock home screen launcher with another one.
4 REPLIES 4
Pascale_F
Moderator
Hi khaeid2
Welcome to the Community.
If you get in touch with
Sony Support about this, they may be able to help.
Thanks,
Pascale
profile.country.HR.title
kinggo01
Contributor
Try clearing cache and data of the launcher and set it up again.
khaeid2
I actually did 2 things
1- Cleared cash and data for home launcher app
2- I have external SSD attached, used as internal memory extending,  checked the location of apps installation, it seems icons belonging to apps installed on the SSD are disappearing, I moved them to internal, and will see
kinggo01
Contributor
ah....... so that expanded storage is still broken then. Since introduction in MM from 2016. And 8GB is still a thing for SONY in 2019.
