Wall mount for sony tv 49xd7005
alexb992
Hello guys.
I recently bought a wall mount for my new tv(fantastic by the way) but the screw that should fix into the tv are too big and wont fit. Does anyone know which kind of screws does sony use by any chance and where I can find them??
Thank you very much.
Alex
1 REPLY 1
Anonymous
Not applicable
Hi there
In general, Sony spare parts can be found on:
http://uk.eetgroup.com/b/Sony
According to page 12 the manual HERE: you will need a wall mount bracket (Model = SU-WL450) - is this the wall mount you purchased?
http://uk.eetgroup.com/i/SUWL450-Sony-TV-Wall-Mount
Page 5 of the manual for SU-WL450 lists the parts - see HERE
