xg8096 voice search problem
pcr123
When I press MIC activate, the light only comes on for maybe 0.5 secs, not long enough to say much, and the TV only shows say half of what I say. Pressing MIC a second time sometimes shows the rest of what I said. Additionally, "google assistant can't be reached" is the usual response to the search.
Thanks.
1 ACCEPTED SOLUTION
pcr123
FYI, this problem turned out to be the batteries in the remote control were low, apparently making the microphone do spurious things.
1 REPLY 1
pcr123
