Cassette will not eject. Power is OK and everything else works including playback from trapped cassette.
I am having the same problem and was thinking of opening the cassette door, but I am not an expect on this and I might damange the whole handycam. Any help, please?
Hi
This is often a power supply problem.
Try removing the battery and powering the camera using the AC cord connection.
If that fails there mustbe a physical blockage which needs a repair, but usually if the tape plays ok it can be fixed with the AC method.
Mick
