Lens problems
profile.country.en_GB.title
Mike.S
Lens problems
Hi,
Anyone having a problem with the lens on their Cybershot not extending or retracting properly might like to look at http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I had a fault on my DSC-W170 which was solved by powering up the camera with the shutter button pressed (suggestion 4).
Hope this helps.
1 ACCEPTED SOLUTION
Blencogo
Thanks for sharing that information Mike.
It is for things like this that this forum was created.  Thank you again for sharing.
:slight_smile:
1 REPLY 1
Blencogo
:slight_smile:
