- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2011
January 2011
How do I move an audio book from itunes to my reader?
I downloaded an audio book from Audible. I can't get into my reader library. It's in my itunes. Any ideas please.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
January 2011
January 2011
Hi, you would need to drag and drop via Windows Explorer, you may not be able to though dependant on the bit rate and codec used on the Audio book as they are designed for a specific product range, this you will need to check on the Audible web site.
