CMT-SBT20B Home Audio System - No headphone socket
SteveSmith21stCentury
Hi,
Just got the above for Christmas and set it up, extended the mains cable, really happy with sound and ready to sit back and listen to music from various sources on headphones.
Except there is no headphone socket.
I've seen on the net some mention of someone having to use NFC Bluetooth headphones with this unit but the mention of headphones in the manual is conspicuos by its absence and I'm not convinced there is a solution here.
Can anyone help? Am I missing the obvious and its assumed Bluetooth headphones will work?
1 REPLY 1
EdwinaU
Moderator
Hi Steve
Welcome to the community.
You're right. With this hi-fi you will need to use NFC bluetooth to connect headphones. You can read more about the specifications and features of the unit here.
Best wishes,
EdwinaU
