Hi not sure if anyone will still have this model of amp but I do and I'm wondering if anyone knows what is causing it?
It's linked up to the TV with the arc thing.... As you can tell I'm not a techie!
The amp is on standby when TV is off so its always got a small heat to the top of it.
But today when the noise started I touched the top it was really hot.... I'm wondering if its getting ready to burn out.
At least it's lasted a long time!
Hope someone can help.
Thanks
Hi,
If it gets hot you shouldn't use the device any more and contact a repair centre.
Peter
Hey @JansenGray71,
Sony has a handy locator tool for service centres in the UK and Ireland which you can check.
Hope this helps!
- JD
