- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I recently bought model BDV-E370 through Pixmania - have installed latest firmware but cannot seem to get BBC i player to work - does anyone know why??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Keith.1967
Indeed I think this may be the cause of it as only UK spec models are configured to work with iPlayer ( due to the way the BBC is funded)
I think it would be easier in this instance to return it to Pixmania and re-purchase it from any good UK based reseller ( either online or high street) as you are probably still within your cooling off period with pixmania I guess, but I guess you'd need to flag this immediately!
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you see the BBC icon at all?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
nope cannot see the icon - have latest firmware - have left on standby for 24 hrs have tried resetting etc but still no icon appears. will changing my ip address have any effect?? other than this i cannot think of what else?? what about downloadable software to update the machine or is it possible to have this taken to a sony repair shop to have software updated to show i player
thanks for any help you can provide.
ps this was purchased through pixmania and suspect therefore not a uk model does this have any bearing on it??
cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Keith.1967
Thanks
