Good morning, I bought the DVD player. I wanted to know how to be able to switch the player
as an audio output source, ie if I listen to CDs I would like to connect to the coaxial output
sockets and for the DVDs to be connected to the HDMI socket. Thank youHi albrun1978,
Try going into settings/external inputs/HDMI set up then set HDMI control to on.
Let us know how you get on?
Thanks,
Sean Mc
The problem is that the player is connected with an HDMI cable to the TV and with
a coaxial cable to the amplification system. I would like when I listen to the CD
the audio passes through the coaxial cable and when I watch a DVD use the HDMI cable,
there is no choice based on these preferences. it's a bit restrictive. how could I solve?
thank you!In my opinion, the only solution is to use the cable also the RCA video cable with the coaxial
audio for when I listen to the CDs with the amplifier system.
Instead when I decide to watch a DVD movie, reconnect the HDMI cable by disconnecting
the RCA video cable and the coax.
It seems to me a solution, however, restrictive
