Sony Blu-ray BDP-S370 will not connect to the internet
stuey9964
I own a Sony BDP-S370 blu-ray player and have done for a while now but since last Saturday it will just not connect to the internet.  It is a wired internet connection and there is nothing wrong with the cables or anything as I use the same connection for my SKY TV box and it works fine.  I have tried a full reset with the player and this also makes no difference.  It just says on the screen cannot communicate properly with DHCP server.  I would be grateful for any help or suggestions.
1 ACCEPTED SOLUTION
stuey9964
I reset my Netgear router and My blu-ray is back up and working!!  Don't know how the Sky box still worked when the blu-ray didn't but who cares!
3 REPLIES 3
JFramel
Which service provider do you use?
Anonymous
Not applicable
Hi there
A couple of things to try:
  • Try replacing the ethernet cable or even unplugging it and replugging it back in (as they can become faulty, or even loose if you've moved things around)
  • Try using manual settings instead of using auto (as in, using a fixed IP address) as this by-passes your routers DHCP settings.
  • Have you thought of rebooting your router?
Hopefully one of those resolves your issue.
stuey9964
