Sony HT ST5000 Audio Output settings resetting every time
profile.country.IE.title
olivier.goutay
Hello,
I just bought a HT ST5000 Soundbar.
Very happy with the sound, excellent soundbar overall.
I'm just confronted to a small issue:
I connect the soundbar to a projector, through the HDMI output port (it's not always connected). When the bar goes in sleep mode and wake up, the sound is sent to the projector instead of staying in the bar.
I can also see that the "Audio Settings">"Audio Output" settings is always reset to "Speaker+HDMI" instead of sticking to "Speaker" only.
Is there a way to make this settings sticky between restart?
Is there another way to make the bar understand that I always want it to be the speaker?
Thank you in advance.
Cheers,
Olivier
3 REPLIES 3
Owen_G
Hi Olivier,
We're looking into this issue for you now, and we'll be back in touch with a response for you soon.
Thanks,
Owen
Owen_G
Hi Olivier,
If you disconnect the projector then the soundbar resets the settings, because the projector is no longer recognized. This is normal behavior. The only option is to keep the projector connected.
Hope this helps,
Owen
olivier.goutay
Hello Owen,
It does not really help, but I guess I'm in a special corner case where I don't have my projector connected all the time.
Anyway this setting could be sticky? (even when you connect/disconnect displays)
Cheers,
Olivier
