I recently purchased the above along with a Sony KD55AF TV. I had it installed for me but it turns out not to have been carried out correctly - surprise surprise!. I should be able to use the remote for the sound bar and press for example Sound Field and the information should appear on my TV screen. It has never. I was unaware of this facility until I recently read thorugh the manual!! By the way half of it I couldn't understand anyway. I visited the store where I bought it and the Sony Expert was unsure. I have been in touch with Sony Support and all they do is provide me additional downloads of manuals! I have checked as best I could all the connections but no joy. Anyone out there who can assist? Thanks Atso
Hi there,
Welcome to the community.
Hopefully one of the forum members will be able to help.
Best wishes,
M
Hi provostkaypark,
Welcome to our community!
If the soundbar is connected to your TV with a digital optical cable then no display form the soundbar will appear on the screen of the TV whatsoever. For example, you will not be able to see the settings menu of the soundbar on the TV. The reason is that digital optical cables can only transfer audio signal and not video signal to show the menu.
Also, it's mentioned on page 29 of the user manual of the sound bar (available here) that the sound field menu does not appear on the TV screen for TV input.
Regards,
Batee5
Hi provostkaypark,
It means that when you select TV an input from the list of inputs available on the soundbar, the sound field menu does not appear on the TV screen which I believe is a system limitation rather than a fault as it's mentioned in the manual.
Regards,
Batee5
Hi provostkaypark,
It's always best to connect all the external devices directly to the TV then connect audio devices via an optical digital cable ot via HDMI in the ARC port. Nevertheless, it should work if you have the devices connected to the soundbar then the TV.
Regards,
Batee5
Batee thanks for your reply. I did as you suggested and as suggested by Sony. Please read latest message I have just posted.
