I am about to take delivery of a Sony KD-55XF9005 and HT-ZF9.
I have Sky Q and a Sony UBP-X800 to connect.
Is it simply a question of TV ARC to Soundbar ARC connection, and then Sky Q and the UBP-X800 to HDMI in to the Soundbar? Is is that simple?
Hi @Blumine1818,
wouldn't it be even easier to connect the Soundbar to the TV via HDMI (with ARC) and then connect the Sky box and the Player to the TV normally via HDMI?
- Nic
Hi Nic
Many thanks for the reply.
That is a good point.
On the TV, not all HDMI are fully 4k compatible to my limited understanding, so the soundbar would passthrough full 4k?
According to the manual all HDMI-ports support 4K.
- Nic
Perhaps I misread the input and output details in the specs section incorrectly.
I thought it referred to HDMI 2/3 only?
It's not very clear to an amateur.
Hi @Blumine1818,
you are not the first person to get confused by the footnotes.
It only refers to Cinema 4K (4096x2160 pixels) resolution and 50/60fps playback.
- Nic
Thanks again Nic
Do I assume from this that I would connect my Sony UBP-X800 to one of these or wouldn't it matter?
Much appreciated
Hi @Blumine1818,
4K Blu-Rays only use 24p max, so it doesn't matter to which port you connect it.
The soundbar has to go on the ARC HDMI port though.
- Nic
Many thanks Nic
I'm all set!
Hi @Blumine1818,
@Blumine1818 schrieb:I'm all set!
awesome
Let me know if you have another question.
- Nic
