Quisiera saber como quitar el bloqueo que me sale ahora cada vez q uso el móvil encendido Le tengo que poner el pin, antes solo lo tenia que hacer al encenderlo, gracias
I would like to know how to remove the block that I get now every time I use the phone on I have to put the pin, before I only had to do it when I turned it on, thanks
-GT
Hi @Amaranda, welcome to our forum!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
You can remove the screen lock on your device if you go to Settings > Lock screen & security > Screen lock > None/Swipe.
The only lock you will need to unlock after doing this is if you have a PIN code for your SIM card that needs to be entered when you restart your device.
Keep in mind that it's advised to use a screen lock on your device (PIN/pattern/password) for security reasons, for example if your device gets stolen/lost, the person finding it won't have access to your personal information.
I hope that answers your question!
