I bought xperia M dual month ago. i got a issue nowadays my vice level is going to minimum to high at the other end. it not sable. warring in 5 min interval in the call. What is the issue? is it hardware issue or some other problem ? it happens all calls from my two sim (aitrel/bsnl)
Download sony update service and repair your device:
http://www.sonymobile.com/gb/tools/update-service/
same problem even on my Xperia M (C1904) after 1 hour call this happens for interval of 3-4 minutes:smileyquestion:
Have you tried repairing?
Do you have microphone noise suppression and slow talk enabled?
