Autofocus Noise
profile.country.CH.title
ric.ferreira
Neues Mitglied
Autofocus Noise
I just bought the Sony 70-200mm f2.8 GM and i think it doesn‘t work as it should.
Autofocus makes a noise when its focusing.
When i change the Aperture from f2.8 to f3.5 and vice versa it makes also a Noise (like a Click noise).
does someone else had any issue like that?
thanks for your help.
1 ANTWORT 1
IamNic
Hello @ric.ferreira,
when your camera focuses, it moves around parts inside the lens via a motor. This makes sound.
The aperture also consists of moving parts.
If you think the sound it makes should be quieter you could go to a camera shop and let them verify that your lens is working properly.
- Nic
