- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
April 2023
April 2023
Sony A7RV & Lensbaby 85 ... how to focus manually with 4.5 Magnification?
Hallo. I own a Sony A7RV and want to take pictures with my new Lens. It is a "Lensbaby 85". ONLY MANUAL FOCUS. No electronic connection to the A7RV. The last two weeks I tied to facus with "focus peaking". But its to inaccurate for macro-pics.
And I can not get the A7RV to work, with the Lensbaby 85 attached, in Magnification Modus. I want to put the magnification modus on a button, but I don't know how. Does anybody know how? Thanks.
2 ANTWORTEN 2
Anonymous
Nicht anwendbar
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
April 2023
April 2023
The closest guess is that it's a compatibility issue really, in the end you're using a non Sony lens, and 9 times out of 10 it won't work, so not sure if you're gonna be able to achieve that really.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
April 2023
April 2023
Hi SkyNet404.
Thanks for your reply. I will try further.
