C510 Battery/update problem
Not applicable
Hi I am new here. My C510 recently stopped working and as i was away from home i couldnt charge the battery. I got home to charge it, but it displayed the error, "Battery cannot be charged. You must use a sony ericsson charger," I have tried using different chargers and batteries, both of which have cost me some money. I also read to update my phone software, but I cant even get on the phone as the battery is dead let alone update the software. Please any idea on what to do? Any help would be much appreciated! Thanks!
1 ACCEPTED SOLUTION
Dr_Chris
Champion
Connect it up to your PC via USB: If it doesn't charge through the connection, is not recognised by the PC and is unusable with and without the PC, contact SE.
2 REPLIES 2
KrazyD
Contributor
If you could charge the battery in another phone or something like that and then run the Update Service.
Dr_Chris
Champion
