Hey, I was wondering if someone could tell me whether a Micro Sd SDHC card would work with my phone? or does it only work with normal micro Sd?
Thanks
I use Micro SD HC class 10, don't buy class 2 or 4, they might be cheaper but the bitrate sucks
Make sure that you mark the Correct & Helpful Answers
Ah I see,
I was considering class 4 but I wont now haha.
Sweet thanks for ya help that solves that issue:-D
anytime
