How to write chinese message.
Not applicable
i was trying to reply to my friend in chinese but was not able to change to chinese input. How do I do it?
1 ACCEPTED SOLUTION
suze
Leader
Try long pressing in the input box and you should then get a popup that gives you the input method option, select that and select chinese keyboard (X10 biggun)
3 REPLIES 3
suze
Leader
Not applicable
Hi Suze,
Thanks. U are a great help...  Slightly_smiling_Face
Not applicable
She is indeed.
You can also use the Chinese handwriter input. It is less taxing on my big fingers, alays tying so har to land on ONE key.....
