I bought the TV last Thusday (28/11/13) and finally got round to purchasing a 3D BlueRay DVD to test out the set this evening.
The blueray system loads up fine but as soon as the TV displays a message confirming along the lines of "3D dispaly found" my TV switches off automatically and the centre 'Sony Lamp' starts blinking, with each blink interal consisting of x4 binks. Incidentely I tried loading one of the apps located in the 3D app store located in SEN and the same issue occured
I then followed the procedues in the Sony guide to 1/ removed the plug from mains(10 mins) and also restored back to factory settings.
Again the exact situation happen as described above.
Would appreciate any advice to rectify this issue on my 4 day old set.
Many thanks
Hi there
Unfortunately you have a hardware error of which cannot be resolved here. As the TV is brand new, my advice is to take it back to the place you purchased it from for an exchange.
Hi there
Hi Quinnicus,
Much appreciated for the quick repsonse, I will contact JL from whom I purchased the set from first thing tomorrow. From the speediness of your reply, is what I am experiencing onmy Sony set a common occurence?
Thanks
Kiy
Hi there
I have not seen or heard a blink code error on the W9 TV's yet (your the first, as far as I believe). So Ill have to say, no its not a common occurance.
Good luck with JL by the way.
Cheer
PS: The speediness of my reply, indicates that I have nothing better to do
