- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Bravia KD-55X8505B Picture Settings
Hi,
I have just purchased the KD-55X8505B and I have left the picture on default, straight out of the box. Is there anyone with the "Best Picture" settings for this TV? The main Input for me is Sky +HD.
First impressions of the TV are good. However, some of the non HD channels through sky are extremely ropey.
I'd appreciate any help with this.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
This one is kind of impossible to answer as best picture settings are an individual taste. Have a read through this FAQ and see if it helps or give you any pointers.
http://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/faq-best-picture-settings/ba-p/1821711
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tried to adjust the picture settings following those steps, but no joy.
I am extremely concerned and I even wonder if the TV could be faulty? The 9 year old Samsund TV in comparrison, displays a better picture with all inputs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Non-HD channels will always look second best on a large screen TV. If you take HD has being 1920x1080, the resolution for non-hd is well far far lower, and with a 55", you are blowing the imperfections of the video even more.
Unfortunately I cannot see to judge whether this is within normal operations, only you can. If you are really struggling, it might be time to give Sony support a call.
Was your Samsung TV a 55" too?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same problem, contacted Sony and they asked what signal strength I had on my sky + box. I had approx. 90% on signal 1 and 50/60% on signal2. Sony say that because I have a larger screen than previous I need at least 80% from both signals. Waiting for sky to reset sat. dish. Check yours its worth a try
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks anspenc51, please let me know if you have any joy with Sky. I'm also waiting now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Sky engineer changed picture format 2 to 16.9 setting, fitted a new power cable and a new dish, picture quality has improved to a good level on sd and a realy good level on hd. TV set on factory settings but will tweek settings to improve. Hope this helps.
