Brightness issues on my VPCS13L9E. Please help!
profile.country.en_GB.title
2ashdb76
Посетитель
Just got a new Vaio (VPCS13L9E) with Windows 7 Professional on it. I've noticed intermittently the brightness will go up and down all by itself! I've checked the power management and the brightness settings there. My brightness keys using the FN button work ok too. It does not seem to be affected by having the power cord plugged in either. Has anyone else had this problem? I've only had the laptop since just before Christmas! Thanks.
Теги (4)
1 ОТВЕТ 1
sibeba
Новый
you've got autro-brightness set. go into VAIO Control Centre and under Display choose Automatic Brightness Settings  Turn off the Adjust Brightness Automatically.
