Does it fit?
Lemoni
Does it fit?
I'm really happy with my new Vaio n31m!
On Ogio I found a lovely bag for my laptop, but the sizes are in inches, and I only know the sizes of my laptop in centimeters (The Netherlands)
Can someone find out for me if my laptop will fit the bag?
And if I have some room left for books and other stuff if my laptop is in the bag?
This is the bag: http://www.ogio.com/product.php?product=449
At dimensions you can find the size of the bag.
Thanks already! :smileyblush:
3 REPLIES 3
profile.country.en_GB.title
kee-lo_
Easy, just type in google:
convert xCM to inches
replace x with the value.
davemee
Google will convert and do maths for you. Ask it "15 inches in cm".
If you're going to put your laptop *AND* other items in the same bag, I'd seriously think about housing your laptop in a sleeve case as well as in the bag - otherwise save yourself some time and scratch the bejesus out of the lid now. Cats can be useful for this.
Blencogo
Bag size - 483mm X 356mm X 102mm
N31M size - 364mm X 265mm X 39mm
