Hello,
I have upgraded to windows 8 from 7 I ran the compatibility wizard it said my graphics card would need an update after install which would be available through windows, guess what? no update, my laptop is some 4 yrs old now so nothing forthcoming on Sony, can somebody point me in the right direction as so a solution.
Many thanks
Bob
Hi Bob,
As I'm sure you are aware, Sony does not support Windows 8 on your model. The situation is made more difficult because Sony moved to nVidia graphics at about the time Windows 8 was released, so most updated drivers for Windows 8 are for those graphics chips.
All I can suggest, at your own risk, is to try to install the Windows 8 AMD Driver Ver 9.1.0.0 which was released in December 2012 for some Vaio models with switchable graphics. I don't know if it will install on your Vaio model but it may be worth a try.
You can find the driver on the downloads page for the VPCSE1S9E which has a newer AMD graphics chip but we can hope it is a generic driver for all AMD graphics using Windows 8.
http://www.sony.co.uk/support/en/product/VPCSE1S9E_B/updates
Look under 'Latest Downloads -> Windows 8 -> Driver' for it.
If this fails to install, come back as there are some more complex possibilities.
Hi there,
Thanks so much for at least replying,
I will indeed try your suggestion and will get back to you.
kindest regards
Bob
Hi there,
my apologies for such a long term reply, things on the family front suddenly went in to overdrive.
I am downloading the driver as we speak will let you know how it goes?
Just to say thanks again for at least pointing me to a possible solution.
Best regards
Bob
Hello again,
sorry to say it did not work, it seemed to install with no error messages I restarted my laptop but still getting the annoying messages popping up, never mind it was worth a try.
once again many thanks.
Bob
