In my sony laptop only DVD is working.Audio CD and VCD not working.Have any solution for this
profile.country.en_GB.title
dischama
In my sony laptop only DVD is working.Audio cd and VCD not working.Have any solution for this?
1 REPLY 1
Blencogo
If some functions are working OK and others not working, the cause is usually hardware related.
Check that the lens is clean by using a liquid cleaner.
Check the lens head can move freely from one end of the travel to the other.
Check for firmware updates for your drive.
What Vaio Model do you have.
:thinking:
