XP Pro dual boot installed on SZ5WCN - NO FKEYS!!! Please help
moseleywebb
Laptop - New Vaio SZ5WCN
Hi All,
After struggling with Vista and its lack of interface with Small Business server we decided to install a dual OS on the C Drive and load XPPro on.
All fine, battled the HD Audio issue after a while now I have no FKey support???
The XPPro wasn't SONY OEM and it tells me that the laptop isn't a Sony??? Is this a BIOS problem??? I have the utilies from Vaio Link with no avail.
Any help appreciated
Os
2 REPLIES 2
Blencogo
Hi Os and welcome to Club Vaio.
Which Utilities have you tried? You need the Original XP Utilities (and the XP Drivers if you have any missing!) supplied for the Vaio SZ3-Series. Download from here : -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-SZ&m=2377
It is essential that you install these Utilities in the correct order to get the Fn keys to work. Download the Utilities and right-click on the .ZIP and choose 'Extract All'. I would extract to C:\Utils.
Run the setup files in this order: -
1. Sony Utilities
2. Sony Shared Library
3. Vaio Event Service
:wink:
moseleywebb
Hi there,
Great thanks. I did exactly that after realising that the identical laptop we have in the studio is a SZ3 with XP Pro on it and the utlilies are different.
The last problem I have is with the camera. Don't seem to be able to use it in Skype it tells me that it might be being used by another application?
Weird, nice to back on XP Pro though, had loads of issues with webmail on Small Business server compositing emails. Bill had decided to eliminate the active x from Vista, thanks.
Any ideas welcome on the webcam thingy. Have installed the camera utility and drivers etc.
Os :slight_smile:
