BSP10 and SRS XB33
profile.country.RO.title
_alexdon_
BSP10 and SRS XB33
Hi all,
Any information if I can pair the XB33 with X11 or BSP10? Somehow to create a party mode, which seems to be available in music center for the new speakers.
Or the older speakers can be paired somehow? Do they support music center?
Thanks.
alexdon
4 REPLIES 4
Hi alexdon,
only newer speakers support this software so it won't work with older devices.
Peter
_alexdon_
Hi @Peter_S. @,
Thanks a lot for the reply. What about pairing BSP with SRS? The old ones. I know two old SRS is possible.
Thanks again.
alexdon
Sonyvores
Contributor
No that's not possible. Plus BSP is an xperia product while SRS is a sony product. that answers it all
_alexdon_
Alright then. Thanks.
alexdon
