Cut In After 10 mins
quarkrad
After 10 minutes I have a cut in by another audio file to whatever I'm listening to.  It is always the same track so I deleted the track from the walkman but it happened again using another file/song.  So ... I formatted another sd card and only put two albums on it (completely different albums to the first sentence).  Again, whatever album I start to play after 10mins a track from the other album cuts in.  Is this some sort of feature you can turn off?  I cannot see a way of configuring the device to do this.  Any suggestions appreciated.
5 REPLIES 5
Sean_Mc
Moderator
Hi there,
Can you let us know what model your query is regarding, so we can try to help?
Best wishes,
Sean Mc
quarkrad
Apologies - it is a NWA35
batee5
Specialist
Hi quarkrad,
Welcome to our community!
Have you tried to reset or initialise your Walkman? If this issue is settings related then resetting the Walkman to factory settings can definitely help. You'll find instructions on how to do that here.
Let us know if this helped.
Regards,
Batee5
quarkrad
Yes, I've tried all of those a number of times.  I'm wondering whether there is something wrong with the device itself.
batee5
Specialist
Hi quarkrad,
If you've already tried all of this and it's still doing the same I think it'll need to be inspected at the Sony service centre. You'll find their contact details on this link.
Regards,
Batee5
