How Do I Connect a Walkman to Naim Uniti (Vn. 1) - with a cable?
wolfiewolfie
Hi there
What is the best way to connect a Walkman NW-A55L to a Naim Uniti (Vn. 1)?  Can I do it through the digital or analogue inputs at the rear of the unit?  Any help would be welcome.
Roger
1 ACCEPTED SOLUTION
wolfiewolfie
Hi Peter
Thank you very much for this. On delivery of the Walkman, after waiting for the little chap to fully charge and then loading some tracks (takes time doesn’t it compared with loading onto a laptop!), I used a cable with 2 RCA phono plugs on one end and 3.5 mm on the other which I had previously bought and used. This was connected to the analogue sockets to the rear of the Uniti and it worked very well. The sound is very good across all types of material. I am now waiting for a bluetooth speaker to arrive early this week coming for the real purpose of purchasing the Walkman.
Again, Peter, thank you very much.
Roger
2 REPLIES 2
Hi wolfiewolfie,
I would try to connect the Walkman as a storage device via USB.
Peter
wolfiewolfie
Hi Peter
Roger
