profile.country.GR.title
i_pap1981
ICFC1PJ-CED
Hi, I have this clock radio with projector. When the alarm ringing and the screen is off the buttons don't act (don't respond) whatever I click. Is there a reset to factory settings function or any other idea ? Thanks.
1 REPLY 1
Anonymous
Not applicable
Hi @i_pap1981
I checked the manual of the device, but I couldn't find any factory reset option, the only thing that you can try is removing the battery and place a new one
You can find the manual here: https://www.sony.com/electronics/support/res/manuals/4528/4786538209c3f7a3b33d34acd33d0b1b/45284782M...
