removing phones from sony system
profile.country.en_GB.title
derrick335
Hi all
        I have a sony stereo fitted in my 61 plate ford kuga how do i remove the previously registered phones
from my system as ford only allow 6 phonesw to be registered can anyone help me
1 ACCEPTED SOLUTION
Thalamus.
Champion
Hi derrick335,
welcome to the Sony User Community forum..:smileyhappy:
Not sure if this is correct for your Ford Kuga's radio but try the following..
Press phone button..
Then press menu the word Active should appear & the currently active phone name & number in brackets should display below..
Then using the centre navigation buttons press the down button once & hopefully debond should appear..
Then press the the left eft or right button to select which phone you want to debond (delete)..
Then press the centre button and it should display debonded..
4 REPLIES 4
Thalamus.
Champion
Hi derrick335,
profile.country.ro_RO.title
priboicosmin
Hi i change my player Sony from my car(Ford Focus Titanium 2008), because was broken, and now i cant use the bluetooth function, when i try to connected i see the device like "Ford Audio" , on the phone display appear to put the PIN , 0000 or 1234 try to connect to Sony but nothing happend.
Because i change the player bluetooth doesnt work??? Bluetooth on the car is Nokia 8M5T-19G488-CK.
Tks,Cosmin.
Graham12
How do you debond if the device isn't available since I have just bought the car second hand
Graham12
Hi my phone said the same pin numbers but the head unit ( radio ) gives a different number you need to use to pair them , hope this helps
