Hello,
is it possible to use the USB-C port as audio-input?
Hi meinsm,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi meinsm,
Welcome to our community!
The USB-C port on these headphones is for charging only and can't be used as an audio input. If you want to use cable connection, you can use the supplied headphones cable instead.
Regards,
Batee5
