Sony xb40 20% significant sound reduce
Rajensss
Hello, I'm wondering is there any way to bypass the 20% sound reduce, its really annoying to have 20% of battery still left, but u can barrely hear the speaker
Tags (1)
2 REPLIES 2
Sean_Mc
Moderator
Hi Rajensss,
Welcome to the community.
We can check this for you and update the thread when we have more information. Meanwhile, maybe some other members will have some tips to share.
Best wishes,
Ed
Win_88
Specialist
Hi Rajensss,
It appears that there is no workaround for this as the speaker goes into low power mode when the battery drops that low to conserve energy. Your best bet would be to plug it in to avoid limiting the volume.
Win_88
