WF-1000XM3
Kmfree
WF-1000XM3
How do I increase the volume on these earphones? After a recent software update the maximum volume dropped considerably and now, even turned up high, they are not loud enough.
1 REPLY 1
Sean_Mc
Moderator
Hi there,
Can you try resetting your headset which should resolve the issue. If the headset still does not operate correctly even after resetting, initialize the headset. You can find out how to perform this here.
Let me know how you get on.
Best wishes,
Sean
