WH-1000XM3 battery drain
vaarsn
Hello,
I've bought this headset about 6 month ago. Everything is perfect except... After the most recent  (or previous one) firmware I've started to facing a problems with the battery. I mostly listening a music from an old iPod Nano or watching a movies from a laptop at ~ 40-60% volume. I've noticed that the headphones  are draining their battery  after ~2.5 hours, then the girl inside of the headphones telling me a couple of times about weak battery level and subsequently turns them off. Earlier, the headphones are kept good,  5-6 hours with active noise cancellation. Please help.
1 REPLY 1
jumpsuit
Hi @vaarsn  and welcome to the Community :slight_smile:
As this is a Sony user forum, its best you get in touch
with Sony Support about this as there won't be a quick fix
we can suggest.
Their contact details are Here
Let us know how you get on.
Thanks
